- Goto iPadOS Setting➔Multitasking&Gestures and select Windowed App
- Run Obsidian in Windowed Mode
- See Top left corner to see overlapping UI
Yes
Window control button should be separated from obsidian’s menu bar
Obsidian Menu bar overlapping OS’s windows control
I’m currently using iPadOS 26. When I run this app in window mode, the top-left navigation/menu button overlaps with the system’s window control (the three dots).
It makes it extremely difficult to press the app’s menu button because the window handle gets in the way. I often end up accidentally moving the window instead of opening the menu.
Is this a known bug in iPadOS, or does the app developer need to fix the layout? See the attached screenshot for reference.
