Disclaimer
Is this plugin open source? Yes (MIT)
Is this plugin vibe-coded beyond the author’s ability to comprehend how it works? NO
Community Directory: Typed Graph
Hi everyone,
Obsidian links tell you that two notes are related, but not how. I wanted my vault to know that Alice works at Acme, has known Bob since 2020, and distrusts Mallory. I also wanted to be able to ask it questions about those connections. Typed Graph does that.
Write relationships in plain Markdown
type: Person
knows:: [[Bob]] {since: 2020, label: "met at NeurIPS"}
works_at:: [[Acme]]
-distrusts:: [[Mallory]]
relation:: [[Target]]is the same syntax Graph Link Types uses, so lines you already have keep working.{...}adds properties to the edge itself.- A leading
-makes the edge negative (a signed graph). - Frontmatter
typegives the note a label. A note inTypes/can declare that type’s properties, allowed edges, template and look.
Query your vault with openCypher
```graph-query
MATCH (p:Person)-[c:contributes]->(proj:Project)
RETURN p.title AS person, proj.title AS project, c.hours AS hours
ORDER BY hours DESC
It supports MATCH, OPTIONAL MATCH, WITH, aggregates, variable-length paths and path variables. Queries are read-only, and results render as a live table or a labeled graph that updates as you edit.
Other features
- Graph view: a full-pane explorer that follows the active note, expands neighbors, and shows edge labels and signs. It doesn’t touch the core Graph view, but the docs show how to color types there with groups like
[type:Person]. - Edge embeds:
{{edge: Alice -knows-> Bob . since}}puts an edge property inline in your prose. - Optional sidecar for power users: a LadybugDB mirror with full Cypher, local vector search via Ollama, GraphRAG with citations, and an MCP server for AI agents. The plugin works fine without it.
It works on desktop and mobile, and it never modifies your notes.
Try it
- Install it from Settings → Community plugins → search Typed Graph.
- The demo vault has a guided tour and a hands-on Cypher tutorial:
https://github.com/Volland/obsigraph/releases/latest/download/typed-graph-demo-vault.zip - You can try it in your browser without installing:
https://volland.github.io/obsigraph/demo.html - Docs:
https://volland.github.io/obsigraph/docs.html - Source and issues:
Feedback is very welcome, especially on the edge syntax and which parts of Cypher you’d find most useful. I’ll post all future updates in this thread.
