I turned both off and restarted Obsidian. It still lists my number “1.” and “-” whenever I press space.
How to fix this?
Thank you
How to fix this?
Thank you
Does escaping the lines (by using a backslash before the numbers and dashes) work for you?
\1. Item
\2. Item
\- Item
\- Item
For numbered lists you actually need to escape the dot:
1\. Item
2\. Item
Yeah any button will do it
thanks
