Sometimes, for unknown for me reason Obsidian freezes for a few mins, becomes irresponsive and occupies 8-11% CPU
I would like to troubleshoot it.
Using Process Explorer
I found it spends the most time in Obsidian.exe!Cr_z_crc32
function, but I don’t know how to proceed to find the root cause of that. Please assist
Does it happen with no plugins & default theme?
Is your vault really stored locally?
Are there third party sync/backup solutions running on your files?
What’s your obsidian version?
What’s the installer version?
Yes, I just checked it in the Safe mode, i.e. no community plugins. The theme is default.
The vault is local, on SSD.
No sync/backup is running.
Obsidian version 0.14.12
Obsidian installer version 0.12.19
Currently Obsidian consumes 18% of CPU
download and reinstall obsidian.
Also sometimes you need to restart obsidian after disabling plugins.
If it happens again, try to record a performance profile.
Ctrl-shift-i->performance->record the slowdown->stop recording → export to file → zip it and upload it somewhere and send us a link.
Thanks, after reinstalling, the issue is gone. If it comes back, I will provide a performance profile
