I am new to obsidian. OS: fedora 40 GNOME
I have installed Tray
plugin and enabled few options such as Run in background
and hide in background
in the hope that if I use the shortcut ctrl+shift+tab
it will open my vault where I will be and when I close obsidian, it will hide instead of closing obsidian completely. The above shortcut was set in Tray
plugin settings.
But now that shortcut is not working and when I manually opened obsidian from menu and choose my vault it will appear that vault is opening (with animation that is vault window is taking over the screen) but then it won’t open.
It was running in background initially but now I have removed that permission of background running from fedora linux setting for obsidian. But I still don’t know how to open my vault.
Thanks.
