Transparent background images aren't syncing
I’m using my desktop as a workstation for note taking but plan on using my ipad for actually using my notes I make. When I look through them on my ipad and iphone some images aren’t syncing up. The images are pretty specific too. They are only images with a transparent background and it’s only some of them.
I’ve used similar images without transparent background and they were able to sync up no problem. So I’m unsure why only certain images aren’t syncing properly?
What service/method are you using to sync the vault between the devices?
Obsidian sync.
What Sync plan are you using? Standard or Plus?
https://help.obsidian.md/sync/plans
If you are using the Standard plan and the images are >5MB, they won’t sync. That could be a possibility.
