Over the last few weeks, I have implemented tracker to map out several values that I store in my daily notes, and all’s working fine.
However, I’d also like to use it to track values that I only need to input on a weekly basis (things like my weight, blood pressure etc). Is that possible?
The issue I’m having is that the name of my weekly review files are things like W48-2002. I’ve been playing around with the Tracker Date format to try to include week numbers, but I can’t seem to find anything in the documentation.
Does Tracker only work with day, month and year values, of it is possible to work with it on a weekly basis too?
Thanks a lot for the help
Hi there
I had the same problem as you and I fixed it by using the creation date of the file as the x value.
searchType: fileMeta, dvField
searchTarget: cDate, dvTarget
xDataset: 0
You can also see an example at: obsidian-tracker/TestXDataset.md at master · pyrochlore/obsidian-tracker · GitHub
