Touch issue
New iPhone user problems:
Didn’t have this issue on android though. I am using iPhone 11, and when I am selecting text from right to left side (if it’s a small phrase it’s fine) but when I am selecting a long line, let’s say, I will get this palette coming from the right side showing me outgoing links. That makes selecting texts hard for me.
Is that a UI problem, or I just don’t know how to fast select texts on iPhone properly yet, I am confused on that part :slight_smile: beg your pardon, devs / supporters …
If you tap on a word and hold it, it should show the selection bars on either side of the word and then you can touch and hold and end to expand or reduce what you want to select.
