METHOD 1
- Use a screen with higher than 1920x1080 (using 2256x1506)
- Set zoom to 100%
- Look at the top left icon
METHOD 2
- Use a screen with 1920x1080 resolution
- Set zoom to 131% (
Command palette -> Zoom In
three times) - (optional) click off the app to use unfocused colors (easier to see)
Yes, this appears in the Sandbox vault with no plugins, themes, or snippets.
No pixel gap
(Example recreated with the inspector on 2256x1506 screen at 100% zoom)
(Example recreated with the inspector on 1920x1080 screen at 131% zoom)
There is a pixel gap
(2256x1506 screen at 100% zoom)
(1920x1080 screen at 131% zoom)
Obsidian version: v1.3.5
Installer version: v1.3.5
Legacy editor: off
Plugins installed: 0
Plugins enabled: 0
I’ve tracked the specific CSS to the .workspace-ribbon.mod-left:before
class in the app.css
file on line 2084. Its settings are as follows:
.workspace-ribbon.mod-left:before {
position: absolute;
left: 0;
top: 0;
background-color: var(--titlebar-background);
content: " ";
border-bottom: var(--tab-outline-width) solid var(--tab-outline-color);
height: calc(var(--header-height) - var(--tab-outline-width));
width: var(--ribbon-width);
The issue with this code is that it doesn’t inherit the * {box-sizing: border-box}
from line 828. This could be fixed by changing the height property value and adding a box-sizing declaration to be as follows:
position: absolute;
left: 0;
top: 0;
content: " ";
height: var(--header-height); /* Changed */
box-sizing: border-box; /* Added */
This would turn into the following:
