Top Bar Auto-Hides in Obsidian: How to Fix It?
I need help to know if there is a way to fix the top bar with the notes I’m working on, even if I stack the tabs, it disappears and affects my workflow.
I attached the images for better viewing. The bar only appears when the mouse cursor is over it.
Are you using a theme or plugin that enables this behaviour?
Not that I know, or can identify which plugin is doing this. My theme is minimal.
This looks like ‘Focus Mode’—a Minimal Theme feature. It can be disabled in Minimal Theme Settings > Features.
Oh my God! It works, and it was so easy! Haha. Thank you so much!"
