Create a table in any note. Type something inside. Use the toggle highlight shortcut assigned in settings. I tried both Command+U and Command+O but they both failed inside the table.I have read troubleshooting guide.
The highlight should toggle.Actual result
Highlight not toggling.Environment
SYSTEM INFO:Obsidian version: 1.14.4
Installer version: 1.14.4
Operating system: Darwin Kernel Version 25.5.0: Tue Jun 9 22:26:22 PDT 2026; root:xnu-12377.121.10~1/RELEASE_ARM64_T8132 25.5.0
Base theme: light
Snippets enabled: 1
Plugins installed: 2
Plugins enabled: 1
1: Dataview v0.5.68
