Three dots are merged in Anki using Obsidian_to_Anki
Hello
I think there is a small bug in the Obsidian_to_Anki plugin (by @Pseudonium) when I export three dots from Obsidian to Anki. Do you have the same problem?
When I put three dots “…” in Anki, for instance 12... see below:
Then using Obsidian_to_Anki it becomes 12… (in one block with narrow dots) as you can see in the html window:
Whereas when I copy-paste directly in Anki it works (look at the difference with the previous one):
Thank you
