Hi all,
I’m not sure if maybe I get something wrong, or if this indees is a bug: if I put the <% sequence anywhere in a normal .md file (not inside the template folder), it seems templater still interprets it in edit more and the display gets messed up. So, if you put something like
Put `<%` in a template file
while templater is active, coloring in edit mode gets screwed after the percent character. Preview mode works fine though.
There’s an option in the plugin settings to turn off tag highlighting. That should do it.
