‘Simple’ things like <% tp.date.now(“dddd DD MMMM YYYY”) %> aren’t working anymore, when they used to previously. The page just shows the command as above, with no parsing.
Up to date on plugins and Obsidian. Reinstalled Templater, reinstalled Obsidian (over the top of existing installation).
Perhaps an update has caused something to change - anyone else got an issue, or know a fix please?
How do you apply the template ? I mean, which command do you use ?
I’m asking because, more often than not, when the template is just returned as it is (without being parsed/run), it was because one would use a Templates core plugin command (e.g.: Templates: Insert template) instead of a Templater one (e.g.: Templater: Open insert template modal) in the command palette.
Without knowing how you’re trying to apply your Templater’s template though, I can’t say it’s the case here though …
Thanks for replying. I think I may have worked out the problem…
Templater seems to have changed the settings to avoid some sort of hack apparently: the setting (forgive me but the precise name I forget) that allows execution of commands upon opening the note. It seems to be a per device setting now. Once I’d flicked this on, all seems to work so far.
Ah yes, the Trigger template on new file creation was indeed changed recently …
(Which could definitely have been the culprit here as it would impact how your template was potentially applied)
Glad to know you possibly fixed the issue you were encountering !
