Hi
I tried to improve my note creation but I still struggle at one point.
With templater, I quickly create a note based on a template with this code at the beginning :
<% await tp.file.move("0000.Inbox/Podcasts/" + (mytitle = await tp.system.prompt( 'Episode Name'))) %>
I have some metada in the template then I have :
<% tp.file.cursor() %>
Now, when I use templater to create a not from this template, everything work well but obsidian ask me twice to put the file name as you can see :
If I enable “Show tab title bar” in obsidian’s options, I don’t have a popup but my cursor is focus on the title bar at first then on the page.
Is there a way to directly focus my input on the file as I already give a name for the file ?
Thanks
