Templater alt +r dont work on existing note
Head of the note
date : <% tp.date.now ("YYYY-MM-DD_HH-MM HH-MM") %>
from : <% tp.system.suggester(["A", "B", "C"], ["[email protected]", "[email protected]", "[email protected]"]) %>
Press Ctrl + R
the suggester pops up and i select A
then popup is closed and the note is unchanged.
I read Your topic is similar to… and dont found a solution
