Template Help Selection
Hello all,
I feel like im SUPER close to getting this to work,
I have a template that I want to select line(s) of text its usually code.
I would then like to wrap this with the 3 `'s
'''CodeType
#Code that is selected will be here
I’m not sure when I should use tR vs <% %>
I believe that is my problem. If anyone has a little explaination id love to hear it.
Here is what I have.
Currently the code was running without errors but not doing what its suppose to. It was displaying the
if (code !== null) {
    tR =
    ``` ${code}
    ${ tp.file.selection() }
Now I changed the code to this:
let code = await tp.user.chooseCodeBlock(tp);
    tR =
    ``` ${code}
and it says
Templater Error: Template parsing error, aborting.
“” is not a function
Thank you
