I’m using How I Manage Projects and Goals in Obsidian | Christian B. B. Houmann (bagerbach.com)
And I’m trying to add this in my goal note
Bar:: `$= dv.view('99 - Templates/Scripts', {file: 'Go - test'})`
Projects:: `$= const projects = dv.page('Go - test').file.inlinks.where(p => { const mp = dv.page(p.path); return mp.tags?.contains('project') && mp.status === 'In Progress'}); if (projects.length > 0) { dv.header(4, projects.length > 1 ? "Projects" : "Project"); dv.list(projects) }`
but when i creating a new goeal note template error apaer and the progress bar doesn’t work
My consol
My dashboard note
Did you happen to figure this out? I’m receiving the same error using dv.view()
The Dataview view loads just fine upon opening the page. It’s when I try to insert a template containing a Templater execution command that I get this error in the console.
the problem happens because of the progress bar script from
when i delete the script, everything works fine, but I had to find another way to use progress bar
system
Closed
May 16, 2023, 8:59am
4
