Steps to reproduce - Video
For this, you have to use Obsidian Android app.
It’s a bit hard for me to describe in text, I’ll link a 30sec video below (hosted in Vimeo), the issue will be immediately clear to you.
Video - Obsidian - Android Bug For Collapsible Items.
https://vimeo.com/1154553571?fl=ip&fe=ec
Steps to reproduce - Text
But I’ll still try to give a text description as well.
- First, let’s say you have a doc which has many collapsible items (e.g. headings, bullet points etc).
- Now, when your Text Cursor is active in let’s say Section 2, but you open a Collapsible item in another section, the screen jumps to the Text Cursor again.
- You can’t just open and close headings/bullet points etc without the screen jumping to the text cursor.
- However, if you remove the text cursor (by opening a side pane let’s say), the issue doesn’t happen, and you can nicely open and close any collapsible items.
Y
Additional Info
I don’t update Obsidian very often, I first noticed it when I updated it in November 2025, didn’t do a bug report back then cause I thought the issue would be fixed next update automatically.
But it didn’t get fixed after the latest update either (I just updated it today), so I’m making the bug report.
- Operating system: android 12 (vivo V2061)
- Webview version: 143.0.7499.146
- Obsidian version: 1.11.4 (277)
- API version: v1.11.4
- Login status: not logged in
- Language: en
- Live preview: on
- Base theme: adapt to system
- Community theme: none
- Snippets enabled: 0
- Restricted mode: on
- none
