If I type a #tag on an indented line following a # header the tag does not become a link. In other words, if the tag is in the section under a header that will be slightly highlighted in preview mode.
Example:
test header
- #tag is not clickable
- neither is #this one
  • but #this one is fine
Indented text, like the following:
#test
is considered a code block in Markdown.
In other words, you are trying to create an indented list but are indenting the list too early.
The following text renders problematically, as you’ve described:
# Test header
	- #Test
…becomes:
Test header
- #Test
But this:
# Test header
 - #Test
…renders correctly:
Test header
  • #Test
Note that the behaviour is the same here in Discourse. Markdown is a funny thing sometimes, sadly!
