I have
tags : [Meeting, SomeThingElse]
in my frontmatter, but the tags are not recognized.
I have around 10 notes with #Meeting in the frontmatter tag, but only one note shows up.
Any idea what I’m doing wrong?
I have
Do you mean Meeting? Because #Meeting wouldn’t work if it’s in frontmatter.
Meeting… why can’t you edit your older posts… sigh
Well, can be many things… some not related with the tags.
tags: [Meeting, SomeThingElse]
The syntax is right? Yes.
You can also use this one:
tags:
- Meeting
- SomeThingElse
Not recognized by who?
Only one note shows where? In tag pane?
Another point: sometimes yaml frontmatter doesn’t work (any field) because it has an invalid character/syntax in any field and is considered “invalid yaml” (to all fields).
found the bug. It is an invalid syntax, but I don’t get the Metadata (Invalid YAML) because of Metatable just failing silently. If I disable that plugin I get the error message.
Thanks for pointing me into the right direction
