Hi there,
I have searched quite a bit but could not find a solution.
What I am looking for is a way to adjust the right side panel (tag pane and the things I have put there) to the same color as the left pane (file browser and the other stuff there)
Is there an option in the settings?
I am using the Minimal Theme and the plugins Minimal Theme settings and Style Setting.
I think an easy option to set this would be REALLY GREAT!
Thank you very much for your patience
