Suggestion/Help: Retain Scroll Position or Highlight Current File in Navigation
When I open a file and return to the Navigation on Android, it resets to the top of the folder structure. This makes it hard to quickly access files located deeper in the directory or in sequence.
I searched the help docs and forums for terms like “retain scroll position” and “highlight current file” but found no solution. I also tried using starred files and the quick switcher, but they don’t address this issue.
Question
Is there a setting on Android that retains the scroll position or highlights the current file in the file browser?
