Sublists and DataView
Having a list like
- a
	- b
	- c
- d
	- e
		- f
and a dataview query
Table without ID
file.lists.text,
file.lists.parent
FROM "test"
I get (as expected):
a -
b 1
c 1
d -
e 4
f 5
How do i have to change my query to get only those entries which have no parent? I tried some WHERE-clauses with file.lists.parent but none of my tries worked.
Do your query report just one row in the top left? I suspect it does, and that you need to split the list(s) into their separate elements in order to achieve your goal.
So something like the following might work for you:
```dataview
TABLE WITHOUT ID item.text
FROM "test"
FLATTEN file.lists as item
WHERE !item.parent
