Stylus and Touch still does not work on Surface Pro WIndows 11
Install Obsidian on a touch device such as a MS Surface Pro 11
Open Obsidian while device is in tablet mode or has no keyboard conncted
Use and stylus or finger to try and select an icon on the vertical left hand pane
Yes
Touch or stylus behaves like a mouse click
Icons are unselectable. The screen registers a touch with an expanding purple circle. Occasionally, maybe every 10 presses, an icon will be activated
Surface Pro 12 inch running Windows 11 on a Snapdragon ARM CPU
