I am trying to manipulate entries in the “Style Settings” and recently each line appears to be wrapped (see images below). Although this does not affect the ability to set things, it does make the window take up a lot more space.
The following images are taken from different vaults
I have tried at least a dozen different themes, believing that was the issue. However, all themes display the same issue.
It is likely one theme did change this behaviour, but how do I remove it and return to the no-wrapped behaviour.
