I have #define inside a Code block, but the tag system detect this as a tag. But it’s not! It’s just a define syntax in C language! How should we deal with it?
example:
    fdsdssdf.cpp
	Line 187: #define
	Line 188: #define
and the define word will be detected as a tag?!
normal #define inside a code block is fine, but in this example, it is not.
I don’t know how to do it;
I find out that I use 4 space in front of fdsdssdf.cpp, and use one tag infront of Line. if I replace the four spaces with one tag, the problem is gone. So is this a bug?
Also another workaround is to use
instead of indentation.
