Stack Tabs Stop Working When Switching Between Edit/Read Mode
Stacked Tabs stops functioning when the pages in the stacked tabs are in Read mode.
  1. In Sandbox Vault, open the pages “Start Here”, “Vault is just a local folder”, “Plugins make Obsidian special for you”, and “Guides/Create a vault” each in their own tab.
  2. Switch the view to “Stacked Tabs”
  3. Click through each tab - they are working properly at this point
  4. Click “Vault is just a local folder” to view it (my 2nd tab) and click the icon to switch from “editing” to “reading” mode
  5. Click “Create a vault” (my 4th tab), so that the contents of “Vault is just a local folder” are no longer visible
  6. Click on “Vault is just a local folder”. The header tab for it appears to activate, and it shows as selected in the File Picker, but the stacked tabs do not slide to make it visible.
Yes
I expect the tabs to adjust properly so I can view the contents of the page I clicked on.
The header tab for the page I click on appears to activate, and it shows as selected in the File Picker. But the stacked tabs do not slide to make it visible.
Obsidian version: v1.8.7
Installer version: v1.8.4
Operating system: Windows 11 Home 10.0.26100
Was fixed 1.8.9
