Edit: this was caused by a problem with a custom theme.
When I try to split horizontally I get this very strange behavior instead.
  • Open command window
  • “split horizontally”
    OR
  • split panes vertically
  • drag one pane below the other
Both of these have the same result.
Two panes stacked on top of each other
Two panes side by side, with the bottom half of the screen empty.
I can reproduce on both mac and windows.
  • Obsidian version: 0.11.0
Does this still happen with no custom CSS enabled and all community plugins off?
It was a custom theme; Warmth apparantly causes this problem. Resetting to the base theme fixes the issue. Sorry!
