When this is on:
If I select a word and double type the open square bracket when this is turned on it puts the double brackets around the work and it becomes a link.
This is great, this is the behaviour I want.
If I turn this feature off though, selecting a word and pressing the square brackets just deletes and overtypes the word with a bracket.
However when I press the quote mark “” I get two quotation marks. While some may find this a desirable feature, I do not. I always end up typing quotes in a different way and end up with an extra quote mark at the end that needs to be deleted.
This setting controls both the brackets and the quote marks.
Is there any chance this could be separated into two separate options?
Auto pair brackets
Pair brackets automatically.
Auto pair quotes
Pair quotes automatically.
If it was, then I could turn off the quotes, but keep the bracket functionality.
According to this post there is similarity with the way Auto pair Markdown syntax works in overwriting words if it’s turned off.
Rename or preferably split Auto pair Markdown syntax
Thank you
