Specific note always reverts to Reading View
I have this one note that always reverts to Reading View. It seems to be the only note doing that (at least that’s the one I’ve been using more often for the last few days). When I open other random notes they are all in Editing View.
Any idea why this happens and how to fix it?
I just tested something, but it’s weird that it behaves exactly the same way: I created a new note, copied and paste the same content, deleted the old note, and gave this new note the same title. This new note also opens in Reading View…
Edit: I noticed that this happens if the folder and the note have the same name. I moved the note to another folder with a different name and everything is working as expected. Can anyone clarify why this happens? Is it a bug?
Do you have a plugin like folder notes installed? It’s most likely one of your plugins which causes this anomaly.
No, I used to have it, I guess, but not anymore. Is it that one where if we have a note with the same name as the folder, the folder becomes a clickable link and it opens the note? If so, then this is not the same issue. This one I’m having, I can see both the folder and the note, even if they have the same name. But it just reverts to Reading View.
Not a big deal, now that I know why it is happening.
