paste the following code:
<< yesterday | tomorrow >>
The text should be displayed as normal text without any special formating because AFAIK this contains no special Markdown syntax.
The text gets very large and bold.
  • Operating system: Linux and Windows
  • Obsidian version: 0.9.12 - 0.9.14
In standard Markdown, a line followed immediately by a line of dashes becomes an H2 header, eg.
This is a header
If you add a line in between the two it should render as you expect.
Ref: https://daringfireball.net/projects/markdown/syntax#header
Ah my bad, you’re absolutely right.
