Spaced Repitition Cloze Color
I am using Spaced Repetition and “{{” for the cloze recognition.
{{ bold or colored text }}
I want to be able to have the text contained within the brackets either bold or a different color so the cloze will stand out more.
Tried various codes and plug ins. Seems the only way is maybe javascript but I have no idea where to start with that :frowning:
I’ve made this post asking for help with the same problem, and found a solution in the Regex mark plugin.
You should find the exact setup if you scroll down on that post
