When a folder is selected and the sorted the entire directory is sorted.
I would like to sort a folder in a directory without sorting the entire directory.
Odd. This works for me. My folders are sorted by Modified Time, while my Vault is sorted alphabetically.
Just double-checked. This time in the desktop version. It’s still true.
How did you do that? On mobile, at least, I can’t select folders and I don’t see anything in the context menu.
I see what’s going on.
I can select a folder by tapping on it, but it doesn’t matter; the Sort options apply to all documents in all folders. It just doesn’t apply to the folders themselves; they stay alphabetized. That’s what fooled me.
So yes, this is how it works. Sounds like a feature request.
Yeah. Thanks.
