Greetings,
Is there any plugin can can give me a sorted Table of Contents?
No. But you could use the Table of Contents plugin and then use the Sort & Permute Lines plugin on the result.
thanks.
Just install “Sort & Permute” but I’m confused how to use it on the TOC.
Select the TOC, open the Command Palette, type “sort”, and choose one of the commands.
You can set a hotkey for command you use often, and on mobile you can add them to the toolbar.
thanks
