I am trying to create a 2 column table of published articles. Column 1 is article title, column 2 is date (YYYYMMDD). The date column format links to my daily notes, which means articles appear in the relevant daily note for when they were published.
Each article has a link to [[articles]] and [[YYYYMMDD]] in a ‘published’ frontmatter field
Here is my code:
table published
from [[articles]]
sort published desc
This creates a list of articles by publication date. BUT: the list sorts FIRST by created notes in date order, and then by uncreated notes in date order.
I want the entire list in date order, regardless of whether or not a Daily Note exists yet for that day.
tbh no idea what to try. I need some sort of ‘over-ride’ to tell dataview to ignore whether the note is created or not
I’m trying to do the same thing: sort by dates, where the date is a link and I want to ignore whether the linked file has been created. My whole thing is a little more complicated:
TABLE WITHOUT ID
"[[" + file.name + "|" + regexreplace(regexreplace(file.name, "^\d+", ""), "\([^\(]*\)$", "") + "]]" as "title",
regexreplace(join(flat([nonnull(creator), nonnull(editor)]), "; "), "\(\W*\)", "") as "creator(s)",
date
FROM (#source or #text) and -#note
FLATTEN dates as date
WHERE contains(meta(date).path, "2024")
WHERE typeof(whole) = "null"
SORT date ASC
I’ve tried string(date) and meta(date).path, which seem to do very little. I’ve also tried meta(date).name, date.name, and date.path which do make things worse (in that I can no longer even tell on what criteria the list is being sorted—certainly not the date).
