- Copy text. I came across this using the text:
The swords is the suit of intelligence, logic, truth, ambition, conflict and communication. It is associated with the element of air. In readings, these cards focus on the faculty and power of intellect, which like the swords themselves, are double-edged.
- Paste it into a note.
- Start selecting words by double-clicking on them.
Y
Every word is selected as you would expect: whole.
Some words (e.g. intelligence) is only partially selected, as if it was detected as multiple words. See video below to understand this.
Obsidian version: v1.3.5
Installer version: v1.3.5
Operating system: Darwin Kernel Version 22.4.0: Mon Mar 6 21:00:17 PST 2023; root:xnu-8796.101.5~3/RELEASE_X86_64 22.4.0
Catalyst license: none
Legacy editor: off
Base theme: light
I opened the raw MD as well to see if it was a paste issue - it’s not, the file looks as you’d expect.
The issue also doesn’t go away by just reopening the tab.
The issue is also present if I enable Source mode.
You’ll see by selecting the same words from here -in-browser- that there is nothing special about them: no weird characters or such.
See video of this behavior.
