Some hotkeys seem to not work in 1.0
The hotkey for Open link under cursor in new window: ctrl + alt + shift + enter
But when I hover my mouse over a link (in note or in left sidebar) and press that combo, nothing happens. Same for open link in new tab, and open link to the right hotkeys. Other hotkeys like Make a new note work, but seems like the hotkeys relating to opening notes aren’t working.
I’ve tried disabling all my plugins and using the default theme as well, but those hotkeys don’t seem to work at all.
Windows 10
works for me.
hover is one thing, the cursor is there is another.
Which is it?
Oh, I guess I thought it meant hover since it says ‘under cursor’ and hovering is putting the cursor over the link. It does work the way you said.
