Snap package does not work on Kubuntu 24.04 LTS after update to version 1.6.2
Config, I still have issue.
Ok I have fixed the issue. You should now be able to get the working 1.6.2 when you install again to build 30.
Here’s the root cause: we’ve changed the configuration for electron-builder recently in an attempt to fix a bug with accents in file paths when using the snap package. This subtle change causes the tool to switch from using a prebuilt template snap, to fully building the snap package from scratch. I believe there might be some bugs with whatever configuration electron-builder is using to build snaps from scratch, as I’ve built the last broken package with a fresh ubuntu install, and a fresh upgrade to a recent version of electron-builder.
In either case, we have rolled back and now uses the prebuilt snap package which seems to have fixed the issue. Apologies for the broken build!
I confirm it works now! Thanks!
Thank you for the fast fix!
I confirm that it works for me too on version 1.6.2 (rev 30) - and as far as I can tell it uses core22 now as a base which is a nice addition
Can confirm the new version is working for me. Thank you for working to resolve this! Always tough to manage dependency chains.
It is core dumping for me… I’ll troubleshoot a little later…
