Smooth canvas zooming using mousewheel
Zooming canvases via a mousewheel used to have the same smoothing effect that the ui zoom button has. This was, apparently, unintended as it was changed in the latest Obsidian release, such that zooming via a mousewheel happens in discrete steps. This makes the mousewheel zoom jarring and just generally unpleasant to use.
The difference can be seen below:
Non-smooth zoom(using mouse)
obsidian_non_smooth_zoom
Smooth zoom(ui button)
obsidian_smooth_zoom
Add a settings toggle to re-enable the removed behavior.
