It would be nice if, like sliders for the different forces, there’s also a slider for the speed with which the forces drop off. It seems like the force-directed graph drawing algorithm converges in about five seconds. However, with more complex graphs, running it for a longer time can improve the results significantly.
Use case
This is the result the graph view currently gives.
This is the result by running the algorithm for quite a longer time.
Under the Forces configuration, add a slider for ‘runtime’ or ‘force dropoff’ (I’m not sure how this is implemented).
Current workaround
Moving the sliders of the forces around keeps the algorithm running as it seems to reset the force dropoff.
