I need to package Obsidian for deployment in an enterprise environment.
The goal is to install Obsidian:
- silently / unattended
- machine-wide
- for all users on the device
- without any user interaction
- using command-line parameters suitable for software deployment tools
Ideally, I am looking for an officially supported installer or parameter that installs Obsidian system-wide instead of per-user.
I searched the forum and documentation for terms such as:
ALLUSERS=1- machine-wide installation
- silent installation
- all users installation
allusers.exe
I found several older posts mentioning the use of ALLUSERS=1 and an allusers.exe installer that was apparently available starting with version 1.6.5.
However, I have not been able to find the allusers.exe installer for the current version, and the methods using ALLUSERS=1 do not seem to work as expected.
Is there currently a supported way to perform a fully silent, machine-wide installation of Obsidian for all users?
If anyone is successfully deploying recent versions of Obsidian in an enterprise environment, I would be very interested to know which installer and command-line parameters you are using.
