I’ve been using AbsoluteGruv(authored) for a while now and recently noticed that there is an annoying border on the sidebar panes (file explorer, calender etc) both left and right only when they are in focus.
I’ve been tinkering with the theme but am currently unable to find a solution for this. nav class in theme’s css could be the answer, but nothing has worked.
it’s this class selector .workspace-leaf.mod-active, which is only applicable when that particular pane has the focus. in your case, this is what makes the border as such. i guess removing it is sufficient.
.workspace-tabs will make it apply to both leaf (left and right) but not the note’s pane/leaf.
but i guess u need an alternative for users to know which tab/pane is active. just good ui/ux practice.
then it is better to leave .mod-active from the class modifier. This makes the border transparent in all instances. Having .mod-active there makes toggling between active-unactive visually undesirable.
It is best to try both once and settle on one that’s more desirable.
