When using Dvorak-Right Handed (DRH) keyboard layout on MacOS, some shortcut keys do not work correctly. Specifically, Cmd+P and Cmd+F do not function correctly. (The dvorak right-handed keyboard layout is a keyboard layout available by default on MacOS and other operating systems; here is an image of the layout. The numbers 5-0 on QWERTY are replaced with letters in the DRH layout. When using hotkeys in obsidian, the program recognizes some keys correctly from the DRH layout but replaces others with the QWERTY layout.
Eg. keys 5, 6, 7, 8, 9, 0, J, L, M, F, and P from the DRH are replaced with Qwerty keys, while the remaining keys use the DRH layout.
This is not a problem in windows.
- Switch to the Dvorak-Right Handed keyboard layout in MacOS.
- Open Obsidian Settings, to the Hotkeys Tab.
- Select “customize command” on any shortcut key.
- Type “Cmd+P” (Equivalent to Cmd+9 on Qwerty)
Expected result: Obsidian shows the command as “Cmd+P”
Actual result: Obsidian shows the command as “Cmd+9” (this is wrong).
- Type “Cmd+E” (Equivalent to Cmd+G on Qwerty)
- Obsidian shows the command as “Cmd+E” (this is correct).
MacOS M1 Monterey
- Debug info:
Obsidian version: v0.16.5
Installer version: v0.14.15
Operating system: Darwin Kernel Version 21.6.0: Mon Aug 22 20:19:52 PDT 2022; root:xnu-8020.140.49~2/RELEASE_ARM64_T6000 21.6.0
Catalyst license: supporter
Insider build toggle: on
Legacy editor: off
Snippets enabled: 14
Plugins installed: 38
Plugins enabled: 32
1: Calendar v1.5.10
2: Checklist v2.2.8
3: Convert url to preview (iframe) v0.5.0
4: Customizable Page Header and Title Bar v4.7.2
5: Dataview v0.5.47
6: Excalidraw v1.7.24
7: Fullscreen mode plugin v0.1.2
8: Garble Text v1.2.0
9: Hider v1.2.3
10: Hotkey Helper v0.3.15
11: Hotkeys++ v0.2.7
12: Kanban v1.4.5
13: Link indexer v1.0.0
14: macOS Keyboard Navigation v1.1.2
15: Obsidian Memos v1.9.7
16: Obsidian42 - BRAT v0.6.35
17: Recent Files v1.3.3
18: Style Settings v0.4.12
19: Tag Wrangler v0.5.3
20: Templater v1.14.3
21: Theme Design Utilities v0.19.0
22: Supercharged Links v0.9.3
23: Zoom v1.0.1
24: Admonition v9.0.5
25: CardBoard v0.5.0
26: Zotero Integration v2.2.28
27: Paste URL into selection v1.7.0
28: Outliner v3.0.0
29: Tasks v1.15.1
30: List Callouts v1.0.6
31: Snippet Commands v0.0.2
32: DB Folder v2.7.1
