Share Function on Android/iOS not embedding attachments when inserting to daily note
This applies to Android and iOS:
  1. Open Obsidian, create new note.
  2. Switch to (what seems to be nearly any) gallery/photos app. Select photos you wish to share, and share to Obsidian.
  3. When the UI switches back to obsidian, tap “import into vault”. After it’s finished importing, tap "insert link(s) into (note title).
Yes. I have 4 phones to test: A galaxy s20 and s24+, a OnePlus 7 Pro, and an iPhone 15.
I am experiencing the same issue with all of them - version 1.10.3.
as soon as I go to APKMirror and install version 1.9.14 (clean install, no snippets, plugins, or vaults) then the issue is fixed on all Android devices. I can not roll back app versions on iOS unfortunately.
Sorry, I forgot to mention in the original post - the reason this is an issue is because there are multiple feature requests from 2023 about adding the ability to select multiple photos on mobile when creating notes. As of now nearly 2026, if you have 20 photos you can still only import 1 photo/attachment at a time through Obsidian editor. The only saving grace was the share function through android, as I’m assuming Obsidian won’t be implementing that feature request.
(Click here - Why using plugins is just not ideal for this basic functionality) Some users suggest plugins - but this ability is just too basic...also, I got kicked in the shins (lol) when Anki (the flashcard app) went down a road where "the new and improved" version dropped support for a lot of beloved plugins. Also, you have to trust more people to not do anything malicious with the plugins, or expose you by accident. They may get bored of maintaining the plugin, lose incentive because not enough donations, quit randomly, etc - that's why the only plugin I'm relying on right now is Omnisearch unfortunately. I'm building my workflow to not use plugins for long term use (unless its a short project maybe).
Attachments are embedded into the note E.g. ![[test.jpg]]
Attachments are NOT embedded into the note - they get entered as an internal link, but without the exclamation mark at the beginning e.g. [[test.jpg]]
this seems to apply to any type of attachment, not just photos.
So viewing attachments on a note created on mobile is nowhere close to smooth anymore, having to manually insert the exclamation mark individually.
However, Desktop versions of obsidian function properly.
OnePlus 7 Pro:
Operating system: android 12
(OnePlus GM1917)
Webview version: 138.0.7204.67
Obsidian version: 1.10.3 (251)
API version: v1.10.3
s20:
Operating system: android 14 (samsung
SM-G991W)
Webview version: 141.0.7390.122
RECOMMENDATIONS :
s24+:
SM-S926W)
Webview version: 142.0.7444.102
iPhone 15:
Operating system: ios 18.6.2
(Apple iPhone15,4)
Catalyst license: none
Screenshots of the debug info have been attached. I’ll attach whatever else is needed.
will be fixed 1.10.4. No ETAs.
The issue still has not been resolved in version 1.10.5 (256).
Operating system: android 15 (OnePlus PJE110)
Obsidian version: 1.10.6 (256)
API version: v1.10.5
Language: zh
Catalyst license: insider
Plugins installed: 7
Plugins enabled: 5
1: Latex Suite v1.9.7
2: Custom Attachment Location v7.4.1
3: Edit History v0.2.2
4: Version History Diff v2.2.1
5: Remotely Save v0.5.25
It works for me now.
Create a new vault. Please, make a screen recording of this happening there and attach it or link it here.
vedio.zip (441.7 KB)
please, check
Hi thank you, its working on 3 phones again (Unfortunately I actually didn’t get a chance to test my OnePlus phone which coincidentally Sam12 uses as well). I tried adding some plugins too and its working.
I’m not sure why it’s not working for the above user…maybe it is a OnePlus thing or a plugin? I’ll have to test it next week.
I’ve already tried closing all apps and restarting my phone, but nothing worked. I don’t dare uninstall and reinstall Obsidian because I rely heavily on its File Recovery feature.
I tested it, and the problem still persists even after uninstalling and reinstalling. The latest version still has the issue, while version 1.9.14 works normally. So I do not recommend that users who are still experiencing this problem uninstall and reinstall the app, as doing so will cause you to lose all your File Recovery data.
the problem seems to be specific to when you tap “inset to daily notes“
Yes, but the previous version worked, so I believe this bug still hasn’t been fixed in the latest version.
Insert into daily note will be fixed in 1.11. no etas.
