Settings not syncing on mobile
Hi, I added a new vault to sync on my desktop, and turned on all of the settings for syncing, but when I set up the vault on my phone today (many hours after setting up sync on the desktop), none of the appearance/theme or community plugins came over. Thoughts? Thanks!
Sync settings are per device. Did you set the sync settings for the phone as well?
I did, yes. Thanks. that did not seem to work.
I have been facing similar issues at my end as well. The mobile sync seems to be very patchy, especially the syncing of settings.
