  1. Verify that in Obsidian’s “Editor” settings “Fold Indent” is enabled & “Fold Heading” is disabled.
  2. Create a note with a heading.
I expected to see no visual hint that the header is able to be folded.
I was given a visual clue that the header was able to be folded.
  • Obsidian version: 0.9.2
The downward arrow does not function. The bug is visual only.
What happens after you close and reopen the page?
That fixes it.
Either navigating away from the page & coming back or a manual refresh [CTRL + R] fixes it.
It seems that it only behaves this way on the first note you create after you set your settings so that heading folding is off & indent folding is on.
Personally I always have both on, but while experimenting I noticed the temporary visual bug.
