Settings and web viewer randomly stop working
So I’ve had this issue where at any random point while using obsidian (even a few seconds after startup) i try clicking on the gear icon and the settings dont appear, and if i try typing an url in a new web viewer page it’s just a grey screen. I tried restricted mode, default theme and it still happens, here’s my debig info:
Obsidian version: 1.13.7
Installer version: 1.13.7
Operating system: Windows 11 Home 10.0.26200
Snippets enabled: 1
Plugins installed: 33
Plugins enabled: 24
1: Omnisearch v1.29.3
2: Highlightr v1.2.2
3: Style Settings v1.0.9
4: Execute Code v2.1.2
5: VSCode Editor v1.0.5
6: Markdown Formatting Assistant v0.4.1
7: Iconic v1.1.10
8: Color Folders and Files v1.4.1
9: Custom File Explorer sorting v3.1.6
10: Advanced Canvas v6.3.0
11: Auto Note Mover v1.2.0
12: Code Styler v1.1.7
13: Paste image rename v1.6.1
14: Extended Browser v0.2.9
15: Auto Link Title v1.5.5
16: Mermaid Block to Image v1.3.1
17: Links with Icons v1.0.4
18: Drag Out v0.1.2
19: Image Converter v1.4.4
20: Copy Image v1.1.1
21: Simple Image Inserter v0.2.0
22: YOLO v1.6.9.1
23: Convert to Markdown v0.3.5
24: Sheets Extended v2.0.2
hi, kirb
I don’t recall: Did you already check to see if it happens in a sandbox vault?
Here’s how: Sandbox vault - Obsidian Help
Yep it happens on sandbox as well
I mentioned a variation of this on Discord a few days ago, but as an experiment, I would try creating a new Windows user account and then try a test vault or the Sandbox vault in that account.
Then you’ll know if the issue is restricted to your main user account or system wide.
Unfortunately i have trouble doing this as obisdian isn’t present in the new account and i have yet to try downloading it again. Fortunately though, ever since i turned “open settings in new window” off it seems the settings have been fixed and always open now
Interesting. By chance, did you have any of your Obsidian windows full screen (maximized) when the issue happened?
Not many, but I recall a handful of folks on Discord mentioning Settings (not the WebViewer that I recall) acting strangely when windows were maximized.
Anyway, glad you got it working for now!
I tried both full screen and smaller screen but it still happens so we know now that’s not the cause
allllllright i just found the issue: i use a folder locker app to keep obisdian to myself locked behind a password, and i just noticed that the web viewer only stops working when i close that program i open to unlock it. it’s still kinda annoying because i need to find another locker program that doesnt do this (i already had this issue with another locker app but didn’t expect it on the current one)
