When I embed (drag & drop) a file, say a PDF, into a note it then has a viewer that is embedded into my note in the middle of my list. In this case, a list of links (or internal links to files on disk) of various documentation. This interrupts the viewing of all of the links.
When I remove the ! to change it to a regular link, then I can click on it to have it open as it’s own tab in internal viewer (or right click and open in external app if I want).
Add a setting to, by default, not create the links as internal (denoted by !) for embedded files when drag & drop
Having to manually remove the !
