Click in the system-level top menu: File > Open Vault
Click the Create button to create a new vault
Input a name for new vault in the input box
Click Browse to select a location where your new vault will be created
Select any folder as your location then click Open to set that folder as your location
Yes
The Location element to update the path where the vault will be created and the Open/Create Vault view to stay open so I can press “Create”
Clicking “Open” from the native file management modal (when setting the location) closes the Open/Create Vault view entirely. The location IS persisted when I open the view again, so this is a minor bug.
Obsidian version: v1.8.7
Installer version: v1.8.4
Operating system: Darwin Kernel Version 24.3.0: Thu Jan 2 20:23:36 PST 2025; root:xnu-11215.81.4~3/RELEASE_ARM64_T8112 24.3.0
Community theme: Tokyo Night v0.2.5
Plugins installed: 6
Plugins enabled: 0
If it helps trace the call, when doing this with a Sandbox Vault, both the Open/Create vault view AND the Sandbox Vault close entirely unlike doing it from a regular vault where only the view will close.
